actually what does it mean?it didnt get it from the other thread that you told me so i wanted some more information about it.
Also here is a small audio sample i took with my mobile phone from my engine at Idle.Is that tapping?Is that normal?It mostly came behind and below the throttle valve potensiometer.I wouldn't say that it would be coming from the missing/broken stud of the exhaust manifold,and also no fumes are coming out of there so i can relax about that.
But is this sound something new to worry about???
Also,when the car is cold,i have 4bar on the oil pressure.
when it is around 70degrees(engine temperature)it falls on 2 bar,idle
When it is fully heated(around 90) then it drops on 1bar on idle.
In acceleration the pressure is 4.5bar
I have plenty of boost,the turbo kicks in in around 3500rpm(i dont know why so late,but it may be the chipped ECU)....
thanks again guys...im still learning...and also a bit heart acheing visuallising the possibility of an really early recondition...turbos,pistons,manifold....too much!!!
OOOO
