Hello guys i have a 1995 URS4 motor and i wanted to know what a good compresion ratio would be ?
Thanks
this will really help me out.
to figure out the km's on this motor.
Cheers.
Mike
...To figure out mileage on the engine? I guess you're referring to cylinder compression. The CR will be same @ 9.3:1 regardless of mileage. Cylinder compression should be minimum 100 bar warm.
Never show a fool a half built house.
Never underestimate the power of stupid people in large groups.
Life is like a **** sandwich
The more bread you have, the less **** you eat
Thanks
Cheers.
Mike
How are you going to determin that then?
The compression is not going to tell you that
RS2 Black - stock 315 HP
RS2 RS blau - stock 315 HP
Sport Quattro - 1005 HP High Octane website
I know it will not tell me exactly the km's on the motor .. but it will tell me if the cylinders are still good. and if there not that means the motor has its share of km's on it... if the compretion is still good then it means that the motor is still in OK condition ..
thanks guys Mike
cheers
