oilcatchtank
  • S4-rider
    • Oct 2003
    • 6
    oilcatchtank
    Can somebody confirm ?
    Why:Engine performance should be better ?
    How: let the hot gasses out with the help of a small tank and filter ?
    How to hooke up ? Does somebody has an example (drawing/sketch) ?
    Should it be like this ?
    motor (sump) --->tank---->filter (ambient)
    tank---->air inlet
    S4-rider
  • Jeffer
    • 2057
    Engine performance is not better. The air entering the engine is no more polluted with oil residue.
    Do a search on the forum, there are loads of threads how to hook up a catchtank.
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
      Actually the engine should perform better, though gains have never been quantified. Gains due to two main reasons -
      1. Air is cleaner without oil mist pollutants which can increase chances of knock
      2. Air is cooler without the hot oil mist - colder air always gives more power
      As for hooking one up - do a search on the forum. Pretty sure I have some drawings posted here before or on s2central.net !
      Paul
      • Fat Audi 80
        • 10547
        It can make a bloody mess in your engine bay though!
        The Perfectionist
          Huh ?
          • Jeffer
            • 2057
            True! Same here, when I forget to empty it. It'll empty itself all over in the engine bay.
            High Octane website
            • Graham
              • 1622
              I thought the catch tank has a valve setup which allows the caught oil to seep back into the sump. I repaired a punctured one for my ex-bosses brother who built a track car out of an M3. He dumped the body, made a new body out of alloy tubing and fitted the M3 running gear into it. It weighed about 700 ish kilos.
              If you really wanted power gains go for the dry sump method as a significant percentage of power is lost as the crank passes from air into oil. Not sure on the figures but IIRC it is up to 25%. But as with all good ideas they all need one essential thing to make them work-----Money
              • bcdesigns
                • Apr 2004
                • 193
                • Country: Portugal
                What is your oppinion related to the quality of the oil that was turned to vapour and after to liquid...?
                I always thougth that filter leave some dirty in the oil too.
                Audi 100 TDI :mischeif:
                MRC remap; Green Injectors; Champion Sparks; Forge DV 006; Samco Intake pipes; K&N filter
                Xenon 6500k; Pillar Boost gauge; Alpine CDA 9835R on Bose with Infinity Sub
                Oettinger 8x18" with GS-D3 225/40ZR18; Bilstein with H&R Springs (-40mm)
                www.autopamplona.com
                www.mrctuning.com
                • Fat Audi 80
                  • 10547
                  Huh ?
                  Perhaps I am making a sweeping generalisation, but whenever I have seen cars with modified breather setups they always seem to be covered in a layer of grimey oil...
                  I stand to be correct though.
                  Cheers,
                  Steve
                  The Perfectionist
                  • volcano rs
                    • Jun 2005
                    • 2265
                    i put my breather pipe under the wing . and the oil returns to the sump.
                    • Mark Halligan
                      • 2001
                      Same here, I found that the filter on top of the tank became really clogged with sludge after a while and hardly breathed at all contradicting the point of having a catch tank/breather system in place, so I launched the small pancake filter and vented straight through a hose under the inner wing.
                      I still get a smell of fumes occasionally, but no where near what I did with the filter stuck on top of the catch/puke tank. Also drains to the sump, helping keep the engine bay free of grime.
                      Mark - Modded
                      • volcano rs
                        • Jun 2005
                        • 2265
                        hello mark how,s it going ? that catch tank looks good is it anodised?
                        • S4-rider
                          • Oct 2003
                          • 6
                          Guys,
                          I heard a couple of things:
                          1) It should be a tank with features to trap the oil ( to prevent the oil coming out the filter)
                          2) the inlet should be in the middle of the tank
                          3) the outlet (filter or not) on top
                          4) don't use a filter but just an open hose because it becomes clogged.
                          What do you mean with wing ?
                          5) On the bottom the return to sump.
                          With a valve setup of course ??
                          So the gadget on the photo is not good enough (69 euro incl filter)
                          Can you confirm ?
                          regards,
                          Ronald
                          S4-rider
                          • volcano rs
                            • Jun 2005
                            • 2265
                            i think you rely on gravity to pull the oil to the bottom of the tank and into the sump and vapours to escape from top . i'm i right ?
                            • S4-rider
                              • Oct 2003
                              • 6
                              something like this ?
                              S4-rider
