Hi, today I connected car to the vagcom to do some trials, but the battery did not last enough. I got following error codes on 2 runs
Also I have some logs of first 3 groups, but i dont know if it helps. I personally dont understand anything from first 3 blocks.
I am adding the log files also
Car is not reliable, sometimes it accelerates well, sometimes not. I am using 98 octane pump gas. MAF, lambda, injectors, coil packs, spark plugs are brand new.
any ideas???
btw, car is a 1995 rs2 at 80K miles
greets
murat
Code:
VAG-COM Version: Release 311.2-N
[B]RUN1[/B] before doing the trial runs around.
Control Module Part Number: 8A0 907 551 C
Component and/or Version: 2,2l R5 MOTR.RHV RS2D01
Software Coding: PMC 4
Work Shop Code:
3 Faults Found:
00537 - Lambda (Oxygen Sensor) Regulation
08-10 - Control Limit Surpassed - Intermittent
00561 - Mixture Adaptation
13-00 - Adaptation Limit (Mul) Not Reached
[B]RUN2[/B] Resetted run1 codes and did some trials in the road, mosly, low rpm and high rpm accelerations
Work Shop Code:
1 Fault Found:
00519 - Intake Manifold Pressure Sensor (G71)
06-10 - Signal to High - Intermittent
[B]RUN3[/B] Cleared codes again
Work Shop Code:
2 Faults Found:
17-10 - Control Difference - Intermittent
any ideas???
greets
murat
