Guys, need your advice on a friends RS2 problem.
RS2 in question has zero turbo boost at all by the seat of the pants dyno! You wait for 3K to come up and the big bang, but nothing all the way to 7000 rpm, it's as flat as a pancake!! I drove it this morning and it is completely flat! no turbo boost at all!
Here's the details:
Chipped by AMD
There wasn't a nut on top of the wstegate, ie it looked like a stock wastgate to me.
The hoses have been pressure tested and came back ok.
New OE dump valve + Lambda.
New WGFV being fitted to be sure...
A Porsche trained experienced tech has had a look at it and pressure tested it, but no fault could be found.
I haven't got VAG COM so cannot read any faults codes.
The car is in at a dealers soon for a free (ish) diagnostic session, so I've advised to pull the motor fuse to clear the memory and store any fresh fault codes.
Can anyone suggest anything please??
It appears not to be a leak and the symptom is ZERO turbo boost.
New RS2 turbo fitted only a short while ago and is 'expected' to be ok, so why the zero boost?
All ideas gratefully recieved. Thanks Guys!
Martyn
Here's the details:
Chipped by AMD
Martyn
)or if there is a big leak (which is not the case either). Then should go in "safety" mode if detecting knock (one of the two sensors could be disconnected or just broken) or too high temperatures through both the Temp sensor on the back of the cylinder head, or the multifunction temp. sensor on the water rail under IM.
S2 central..... looks as though i need your help...
