I've seen alot of people going to soild tappets, not on this forum though. Now, to convert a ABY for instance, couldn't you just use the tappets from a older VW/Audi engine that had solid tappets?
What would the performance gain be? I've seen cams being sold that are "only for soild tappets" or "only for hydraulic lifters/tappets" - is there a difference? Are the cams made for hydraulic tappets compensated for the deviation of the tappet, meaning a conversion to solid tappets would give them toooo much lift? How much more lift is so?
How would you adjust them?
