looking for good supplier of racing crank for 5 cylinder anyone recommend a good company that they have used and can confirm so thanks gary
racing crankshaft
Originally posted by jogi730Aelred and get you a crank that has been knifedged and balanced.
Chris
Looks like the one on the right, only about 1 Kg lighter than stock thoughAttached FilesMark - ModdedComment
I thought the whole point about balancing was that it was done in line with things like flywheel and clutch connectedOriginally posted by jogi730Aelred and get you a crank that has been knifedged and balanced.
Chris
Cheers n
Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey
With every option available
(except a towball)Comment
Machining was £200 inc initial balancingOriginally posted by rotoryboyOoooohh How much was that??
Yep it has to go back with the front pulley, flywheel, clutch etc. for final balancing as a unit, just waiting for my ally flywheel to arrive from CeesOriginally posted by HPmuirtI thought the whole point about balancing was that it was done in line with things like flywheel and clutch connected
Si
and it will be going back to be finished off.
had a quote of farndon in coventry a few years £2500 .they kept writing to me asking if i wanted it couldn't get them of my back .
Originally posted by garymmachined standard crank not what i want i want a billet steel crank good for 10k rpm anyone?
Ok, enlighten us! How are you going to buzz an engine to 10K.
Unless you want a peculiar stroke. I can't see why you want to spend that kind of money on a component like that. You would be better off sinking into the top end!
Besides billets are not necessarily even as strong as a forged component due to the grain structure!Comment
1 Kg makes a big difference when the engine is accelerating, basically it means that more of the power produced will be available to accelerate the car as opposed to the crankshaft itselfOriginally posted by Mark HalliganLooks like the one on the right, only about 1 Kg lighter than stock though
S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!Comment
