full boost at last !!
  • batty
    • Jul 2004
    • 81
    just a quick note to you guys....
    YEE-HAH !!!!
    I've had my S2 for over a year now, and have slowly been reducing the number of niggling faults. A while ago I fitted homefries and although the performance was at times startling, it was also a little erratic. After reading several previous posts on the forum, I fitted a new WGFV and DV (from S3).
    The result is astounding - more power than I thought possible, in a constant and usable form. It seems like the motor has always been suffering from poor boost control. I've got to say, there's nothing like a turbo motor in fine health !!
    Also, I think the poor idle problems are solved, although I have a new ISV in reserve just in case.
    Thanks for all the shared advice.
  • europeanme
    • Oct 2005
    • 3817
    WGFV????....DV??......ISV??.....what are these, as I have an "issue" with boost at the minute......
    Mike
    • jon_91_s2
      • May 2004
      • 253
      • Home: England
      Mike
      WGFV - Wastegate Frequency valve
      DV - Dumpvalve
      ISV - Idle Stabilisation valve
      If the WGFV or DV are knackered these can cause boost issues. Both cheap parts and not too difficult to change.
      Have yo had your car pressure tested for leaks and have you done the 'Mark H' intercooler mod?
      Jon
      91 3b S2
      Now Sold
      • batty
        • Jul 2004
        • 81
        hi jon
        yep - did a pressure test & not surprisingly, the intercooler was leaking excessively. The O-ring was destroyed (looked like it had been mis-assembled from new !!). Did the MarkH mod & all sorted.
        having fun at the minute setting off from traffic lights in the wet. It feels like boost is being produced earlier in the rev range as well as a lot more and smoother higher up.
        It seemed like the boost never really had time to develope fully in first gear. Very crisp now though - lots of first gear action !!
        • dan_b
          • Sep 2003
          • 3670
          This is good to hear! Is your car standard?
            Nope its homefried Glad to hear all is finally well...
            • dan_b
              • Sep 2003
              • 3670
              Homefry - excellent! The car should be driving with a real zing now, which is what we all want to hear, nice one
              • europeanme
                • Oct 2005
                • 3817
                Jon,
                Cheers for that i will look into changing the parts....and Yes 'Mark H' mod next on cards
                • stevieyid
                  • Apr 2005
                  • 2251
                  looks like i will be doing the Mark H mod next then. How hard is it to fit? cheers
                  3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
                  • madS2
                    • Nov 2005
                    • 552
                    hi,anyone west yorkshire way to look at my s2 struggling with boost after 3000rpm?
                    Looking for an S2 ABY
                    • jon_91_s2
                      • May 2004
                      • 253
                      • Home: England
                      Well I managed it and I am useless. Need to take the bumper off. There are full instructions on here somewhere.
                      Jon
                      91 3b S2
                      Now Sold
