Hey folks....time to test that grey matter.....
My cooling fan does not run when I turn the ignition off, but I have checked all fuses and relays and still cannot get to the bottom of this one. I assume that as with my 2.8 Coupe, the ABY S2 fan should continue running, along with the afterrun pump, when the ignition is switched off?
The fan runs fine, kicking in at 90 when idling and still runs when the engine is then turned off but the ignition remains on. However, as soon as I turn the ignition off, the fans stops
Can anyone shed any light on this...please
I have no known blown fuses and have changed all 3 small grey relays in the engine bay fuse/relay box which are numbered 214 (I thought they were the fan controllers).
Cheers n
Si
Cheers n
Si
....murphy's law eh?
