What is the lifespan of an oil pump and when is ir worth changing?
Oil Pump
I would love to know too as i'm in the process of rebuilding an ABY with approx 100k miles on it, anybody
I cant see any of the internal parts listed in ETKA only a part number for the complete pump, sounds expensive
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
Idler pully mount for the timing belt is one difference between them, 7A/3B motors have it mounted on the top of the oil pump, and the water pump adjusts the belt tension. ABY has the idler mounted on the block and its used for adjusting the belt tension.91CQ20v - Gone to a new home
