AAN 90k miles, intermittent stumble on idle, sounds like 4 1/2 cylinders, seems to come and go at random. Also has a hesitation at 1200rpms and 1800rpms, like a small miss but it’s always there.
Cant find any leaks but i dont think were getting full boost, today i was getting 1.9bar on the onboard computer and twice i managed to get 2.0bar. Anybody know what i should get with a urs4, stock chip?
So far i have changed, O2 sensor, Spark Plugs, Coil Packs, MAF, and checked for airleaks over and over. After changing the coil packs the problem went away for 2 weeks then came back again.
No fault codes, only thing odd is the lambda value with the vag com constantly fluctuates when the engine is stumbling, values jumps around from 960, 1020, 980, etc etc, only sits a steady 1000 on overrun.
I have a complete ABY engine so i can change bits out to test, i need some more suggestions to try
Thanks,
Mark.
Thanks,
Mark.
