Some of you may be following the threads on other turbo car forums (including audis)regarding the use of copper rather than platinum plugs. I will not go into all the arguments here, but I have been very interested in testing "old fashioned" plugs for some time...Last week I sourced two packs of NGK BKR6-E and having proved that the extended nose was not going to come into contact wth piston/valves installed them. These plugs are an alternative fitment for the 7A engine, but are being used in I5s and 1.8T/ 2.7Ts elsewhere - some of them high output motors. Plug gap left @ 0.8mm as supplied. The extracted F5DPORs have evidence of detonation ( minute metallic particles on insulator and centre electrode ). I think this may be due to a clogged fuel filter ( recently changed ) as my fuel economy has worsened slightly ( cold weather not helping either ).
Anyway, with much trepidation I started the engine. No unusual noises, so off for a test drive. I have now run them for three days of mixed usage journeys including motorway and start/stop traffic. I am very impressed - smoother tickover, better pull from low speeds and very free revving. Will pull next week end to check their condition. If we have to keep checking plug tightness anyway, might as well put a new (cheaper) set in whilst the coil pack cover is off. ( Copper will not last anywhere near as long as platinums so I intend to replace with oil/filter at 5K intervals). YMMV - my experience (so far) bears out what I have read elsewhere.........................
