Hi,
Seems my car is drinking a reasonable amount of coolant at the moment, feels perfect on the road, isn't getting hot and seemingly just a small amount of whitish grey 'scale' in the coolant exp. tank. This scale has been around on and off for a fair while but they is no real evidence of an impending problem in the same way my old astra showed with gunk in the tank and gunk on the oil filler cap too! I'll get a pressure test done - what pressures should I expect? I am expecting if there is a problem it will be in the pot nearest the firewall as that always seems to be the weakest...
If it is a gasket failure in the making, while the head is off I was thinking of changing the gasket for a metal RS2 version, plus the valve guide oil seals as i know these are worn. Can anyone suggest anything else which should be changed. Also how long should I expect this to take? I am contemplating doing this myself - is this task best left to an expert or is this something an amatuer can do given time etc.....?
Cheers,
David
Cheers,
David
