MD357 Turbo
  • DJones
    • Jun 2005
    • 2020
    MD357 Turbo
    Anyone tried the Turbo Dynamics roller bearing MD357 turbo?
    Turbo Dynamics state:
    Special .6 A/R turbine housing to take garrett cartridge. High flow GT30 compessor wheel, 0.60 A/R To4B modified compessor housing and seal plate assembly, compact GT25 angular contact roller bearing core assembly, left hand thread GT30 "low inertia" shaft & wheel assembly, recommended maximum boost level is 32 psi.
    Any comments or views? what sort of max power do you guys recon it can deliver TD's recon its good for 450bhp.
  • diesel des
    • 3896
    Its basicly a GT30R on the compressor side in a old t4 housing from what i could tell when i talked to them. Something a bit different on the turbine side though....
    Will require new oil lines me thinks...
