engine timing!
  • nothelle300
    • Dec 2005
    • 201
    engine timing!
    could someone help me with how to check that the timing on my s2 has not slipped out of place and is the cause for the engine now not starting!Got as far as pulling bits of the front off,but im a bit of a novice really!
    dean
    nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
  • Doug_RS2
    • 3847
    mark on the flyweel can be seen through the access hole on the bell housing - from the passenger side - you will need a torch. The crank pulley has a mark that lines up with the cover behind it. The cam pulley lines up with the mark on the cam cover. THe cams have circles on the pulleys - they shoudlface each other so that you can only see half of each. The dizzy cap has to come off to see the maeks on the dizzy housing lines up with teh centre part.
    HTH
