Bleeding the System HELP Please
  • GirlRacer
    • 747
    Hi, after the efforts of trying to fix the front rad, water still dripping out.
    So its a bypass thing to get me back on the road.
    But ive searched on bleeding the water system, and am confused.
    It mentions the bleed screw on the aux rad, but with it being bypassed
    what else is there to do.
    Tina
  • Corey
    Banned
    • Sep 2003
    • 2793
    A good tip while filling the system is to loosen the bleed screw and before filling undue the expansion tank from it's mountings and have an assistant raise it above the bleed screw, then fill it with the coolant and you end up with an air free system.
    Corey
    01636 822288
    • Jas11n
      • 5067
      Bleed screw is on top of the main rad, not the aux rad.
      Be carefull with it.
      Set your heater to full blast and hot.
      There is also a bleed screw on the heater hose that goes through into the cabin on the bulkhead, again be carefull with it.
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • rotoryboy
        • May 2004
        • 3281
        no Tina, there is a bleed srew at the top of the Main red and one of the pipes that goes into the cabin for the heater matrix
        Mark
        Race Clio RS197
        S2 Coupe ABY (Green) - RIP
        S2 Coupe ABY (Blue) - Sold
        • GirlRacer
          • 747
          thanks ... my boyfriend has read this and at risk of sounding stoopid! is he right in thinking he starts car and puts cap back on expansion bottle? before bleeding?
          cheers
          tina
          • rotoryboy
            • May 2004
            • 3281
            Start car
            leave cap off
            heater on full
            open bleed points
            run upto temp
            wait till air starts to dissipate then close bleed points one at a time
            Mark
            Race Clio RS197
            • dan_b
              • Sep 2003
              • 3670
              Tina when you say you've "bypassed" the aux rad, how have you done that - just double checking that you've plugged the two hoses completely, you haven't joined them up together?
              • GirlRacer
                • 747
                ermm, dunno?
                • rotoryboy
                  • May 2004
                  • 3281
                  well go and check, lmao
                  Mark
                  Race Clio RS197
                  • GirlRacer
                    • 747
                    yeah joined em together why? is this a problem? thought could bypass it?
                    tina
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      If you join them the hot coolant just loops in the system without being cooled.
                      Plug them so that you force all of the coolant through the main radiator, so it gets cooled.
                      SS
                      • dan_b
                        • Sep 2003
                        • 3670
                        It is a problem - basically you've just bypassed the entire radiator loop completely so the hot coolant never runs through the main radiator - plug them!
                        • GirlRacer
                          • 747
                          Yeah, its getting bunged.
                          tomorrow will sort the bungs n clips 1st thing, as also need more antifreeze.
                          3 nights without driving
                          • dan_b
                            • Sep 2003
                            • 3670
                            Phew, you had us all worried there for a second!
                            We share your pain of having gone 3 nights without driving your beloved S2, it hurts doesn't it...
                            • GirlRacer
                              • 747
                              Luckily i read things properly again, as it WAS just bypassed
