Lovefab manifold & GT4088R setup 4" downpipe tial 44mm
  • olsonjus
    • Dec 2003
    • 293
    Here are some pictures of my new setup from http://www.Lovefab.com
    They do amazing work
    The setup is their custom heavy walled stainless steel header, 4" stainless downpipe, tial 44mm wastegate, wastegate dump tube(will be extended). The headers go for $1100 US. I highly recommend them
  • olsonjus
    • Dec 2003
    • 293
      which IM are you using? do you have to cut the wing for that manifold?
      • olsonjus
        • Dec 2003
        • 293
        That is actually a vw 16v short runner intake manifold. I am having sheetmetal intake manifolds produced by the same guy for the audi 20v. They should be available in the next few months.
        I am also working on a design that is more symetrical as I've moved the radiator up front in my car, so I have a lot of room to play with.
        Regards,
        Justin
        • S2 Ant
          • 3682
          Any more pics of the EM? inside the collector etc? looks nice from the outside tho
          Ant
          2011 Kawasaki Z1000
          • olsonjus
            • Dec 2003
            • 293
            All of the pictures I have online are here:
            I will upload more pictures when I get home tonight.
            Regards,
            Justin
            • aronmatic2
              • 2129
              • Country: Hungary
              4" downpipe? how did you fit? cut the halfshaft???
              Real carbon parts for S2 and RS2. Check Carbondesign on facebook
              • olsonjus
                • Dec 2003
                • 293
                To be honest, the downpipe needs a bit of tweeking. Just one cut and weld. It touches the cv jount slightly, but just needs to be moved forward slightly. The type 44 has plenty of clearance around the subframe in this area tho. The downpipe was built on a couple quattro which I assume has much less clearance in this area.
                Regards,
                Justin
                • Jeffer
                  • 2057
                  Justin, any idea when it will be showing it's full potential? I'm also leaning towards a GT40R. I saw that Javads car made full boost @ 5000 rpm.
                  RS2 Black - stock 315 HP
                  RS2 RS blau - stock 315 HP
                  Sport Quattro - 1005 HP
                  High Octane website
                  • olsonjus
                    • Dec 2003
                    • 293
                    Here is a dynochart of Cody from Lovefabs s2k stock motor at 16psi with his gt4088R, 4" downpipe and all. Just a stock motor 2.0 honda.
                    The gt4088R will spool fast with 4" exhaust. Imagine what my stroker motor will do with it. Open 4" downpipe, and 2584cc to spool. Should be very responsive
                    Here are some pictures of the collector for those that want to see the nice weld/fab work...
                    • ridgeracer
                      • Sep 2005
                      • 189
                      • Country: Norway
                      Nice Work !
                      96 RS2
                      94 urS4
                      02 ALLROAD
                      • olsonjus
                        • Dec 2003
                        • 293
                        Here is the compressor map for the gt4088R:
                        and the gt4294R that I want to step up to:
