Hi all, Merry christmas and happy new year!!!
well i took my S2 Avant into local Audi dealer for a diagnostic, got the print out, but of coarse its all in Spanish but i will do my best to translate it.
5 errors detected 2,2l R5 MOTR RHV HS D01
1. 00525 003 Sonda lambda G39, no signal, somtimes.
2. 00561 013 adaptation of the mix?, does not stop at the limit of adaptation.
3. 00544 027 boost excided maximum, signal not plausible, somtimes.
4. 00561 014 adaptation of the mix?, surpased the limit of adaptation.?
5. 00513 003 Transmission of the state of motor G28, no signal.
My problem is an intermitant one that is extremely annoying, I get a sharp loss of power sometimes around the 3,500rpm to 4,900rpm range once it starts doing this it will continue to do so until the engine is restarted and not always will it clear up then.
It never happens when the car is cold, but then i dont push it until the oil temp is off the 60 degrees point. Somedays it doesnt do it at all but it still feels quite abit slower than when i bought it back in July.
The car was last serviced about 7 months ago according to log book and ive done about 6,000km in that time.
It has had a new MAF fitted recently before i bought it (looks new and shiny)
plus i have fitted a new radiator due to a crack.
This may not be relavent but the antifreeze i have to top up about ever 2 weeks half a litre. And Engine oil Castrol GTX3 5w - 40w synthetic or Castrol RS formula (not much choice in engine oil locally) about 1 litre a month also having to top up.
Car was running noticibly better for a couple of days after the diagnostic but then the problem re-occured and the performance is not what it should be again.
Have got a good mate who is a petrol head coming over monday to have a look but knowing where to start. Any help on this would be greatly appreciated!!!!
