auto cad; engine mounts
  • Roer_S
    • 40
    need auto cad drawings for the engine mounts for my S2 coupe 91. also need for the gear boks and the diff
    need this so i can make my own in alu instead of the moving rubber!
    Audi S4 avant
    Audi S2 coupe
    x-Dodge Ram 3500 Big Duley
    x-Audi A4 TQ
    x-Audi S4 sedan
    x-Audi S2 coupe
  • Jeffer
    • 2057
    Thats going to be a hard ride
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    • AnLe
      • Dec 2003
      • 291
      naah, it is not so serious job.. just go with the flow
      • caterpillar
        • 2480
        use the hocceypuck.....or some mashineshoes...for the kompressor,or a steelmill
        • rspeed
          • Oct 2004
          • 20
          mustang 5.0 trans mount. i have them in my car . not too bad
            @Rspeed, are they a direct fit, does it reduce the driveline shunt and power delivery?
            Is there increased noise in cabin?
            • Corey
              Banned
              • Sep 2003
              • 2793
              I contacted the manufacturer and talk about unhelpful,
              although I know Summit Racing supply them
              See here for a full account
              Ignoring the front snub mount for now! Are there any real life BTDT's for making/using solid engine mounts on a I5 WR ur? Not really bothered about the vibration issue, I just want to be able to transmit all the grunt from the engine to the floor. All suggestions welcome :D
              Corey
              01636 822288
              • Doug_RS2
                • 3847
                Have you got them Corey? What are they like?
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  Not yet Doug.
                  I still havn't made up my mind to use the Mustang version or go the hockey puck type route. Having looked at the fabricated items in the image further up it has given me a few ideas that may mean I make my own.
                  I always prefer to make rather than buy.
                  If someone knew the properties to a plastic like the stuff used in the poly bushes it may be even simpler and still keep a bit of the engine vibrations down
                  Corey
                  01636 822288
                    You would only need to know the differen shure information wouldnt you?
                    • Roer_S
                      • 40
                      where did you get that ones? looks nice
                      Audi S4 avant
                      Audi S2 coupe
                      x-Audi A4 TQ
                      x-Audi S4 sedan
                      x-Audi S2 coupe
                      • Corey
                        Banned
                        • Sep 2003
                        • 2793
                        Greg, yep the shore value would be fine.
                        Corey
                        01636 822288
                        • AnLe
                          • Dec 2003
                          • 291
                          friend made them, they look nice, they work nice, and they give more noice than hydros but they are far away from solid ones.
                          The rubber was hard to find, needed to find such diameter of rubber that there were same insidediameter of pipe to make it heat resistant, and those big washers, the idea was to save money and not to use polyurethane(?) but to make it last the beating, good support was needed, and to kill 2 birds at once, the pipe under and upper shielding the rubber makes the 5mm thick plate very rigid.
                            Ive got a feeling the black ones are 90 shure, will check in my emails somewhere because powerflex told me what ratings they had used on the wishbone bushes. the black ones are the hardest
                            • rspeed
                              • Oct 2004
                              • 20
                              direct bolt on in my coupe, a little more vibration at idel, but it is polyurathane. no driveline shunt, perfect power delivery. and for vibration i have no issues with that eather
