RS2 problems
  • rs2paul
    • Jul 2005
    • 58
    RS2 problems
    Just had my RS2 turbo reconed by ATE, after I blew it up at Castle Coombe.
    All was good for the first 350 miles but now at low rpm the unit is very
    Chattery & at 3000 to 3700 rpm in every gear they is a low pitched noise/vibration
    (sounds like blowing over an empty bottle) & with a constant whine,
    Sound like I’m being followed buy an ambulance??
    The performance has dropped off, plus I’m getting a pulsing boost?
    Do I have boost leak? Or a knackered turbo?
    I spoke to ATE, they said check the end float on turbo shaft which I did &
    I could not detect any
    Any ideas
  • rs2paul
    • Jul 2005
    • 58
    Sorry i ment AET not ATE
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      Boost leak or broken DV?
      What caused the turbo to die in the first place?
      SS
        Paul, was yours the Blue RS2 that blew the oil breather pipe off in one of the earlier sessions?
        • AAH!
          • 497
          • Home: United Kingdom Current: Bhutan
          as mentioned above sounds like a dv problem.
          formally RS2 +
          • rs2paul
            • Jul 2005
            • 58
            my old unit had done 175,000 miles, & all the castle coombe action blew the seals
            & when i took if of it was locked solid?
            • rs2paul
              • Jul 2005
              • 58
              Also when i replaced to turbo i replaced the pressure reg valve (DV) & the wastegate diaphram with new parts?
              • AAH!
                • 497
                It is unlikely but it might be worth checking to see if the DV has been fitted the correct way round. And for the cost of a new DV (£20 -ish. IIRC you can use one from a S3) it may be worth changing it just in case.
                see here for a previously posted pics:
                Your next stop would be to do a pressure test. If ever you are in west/central London I could help you with this.
                HTH ... Angus
                formally RS2 +
                • rs2paul
                  • Jul 2005
                  • 58
                  What a w--ker i am.... Angus i have just check the position of DV!! & you guessed it,
                  wrong way round???
                  so i will swap round & let you know, thanks for the offer of pressure test..
                  Paul.
                  • AAH!
                    • 497
                    Hope that solves the problem.
                    Angus
                    formally RS2 +
                    • rs2paul
                      • Jul 2005
                      • 58
                      just fitted the DV corectly!!!
                      It has transformed the car!!!
                      I thought it was quick before??
                      Many thanks.
                      • Doug_RS2
                        • 3847
                        If changing the diverter round the other way transforms the car (on boost) there is probably a boost leak somewhere.
