Changing the wastegate diaphragm?
  • GreenDestiny
    • Apr 2004
    • 4
    Originally posted by Doug_RS2
    Austin - what is wrong with your car?
    Where are you?
    Hi Doug,
    Basically some times when I floor the S2 (late 1993 six speed) it dramatically loses all power for a split second. The effect is the car jerks violently until I let off the power.This usually happens when I am in a high gear and just using the turbo to accelarate rather than changing down a gear. If I stop and turn the ignition off and on again I may not see the same problem again for a week.
    I am usually between milton keynes and Northampton.
    Thanks
    Austin
      Originally posted by GreenDestiny
      Hi Doug,
      Thanks
      Austin
      Didnt Ski have a similar problem and it was a faulty injector module?
      Might be worth asking him if your sympthoms are the same as his were.
      LOL i'm a forum buff and i dont officially own an S2 yet!!
      Surprised Dan_B hasn't point this out yet!
        Pull fault codes then lets talk !
        Paul
        • GreenDestiny
          • Apr 2004
          • 4
          Paul
          Hi Paul,
          I pulled the fault codes recently and there was just one '0544 maximum charge air pressure exceeded'. if I power off and on again this will dissappear. I have to get the problem to happen (floor it in a high gear usually does it) ,leave it running and then hook it up to the computer.
          Austin
            #20
            That'll be caused by an air leak. Are you a 3B or ABY ? Where are you ?
            Paul
            • GreenDestiny
              • Apr 2004
              • 4
              #21
              Paul
              Im pretty sure it's an ABY. I am in Milton Keynes.
              From reading about similar problems on this list I had my mechanic check all the hoses and he reckons they are all sound??? As far as I know he used a compressor to actuate all the air activated components like the wastegate and dump valve and they all seemed fine. He also figures that if it was a hose I should be able to hear air sounds in the car. I do hear good old turbo whoosh type sounds etc but nothing out of the ordinary.
              Austin
