what turbo is this
  • topsparky
    • Oct 2005
    • 2014
    what turbo is this
    `hi guys just wondered if any of you lot know what turbo this is sorry no pics still on car and can't see id plate properly since my accident.the number is 53 26 101 5071 1821 226 cheers guys i think it's a k 26 it was already on my s2 when a bought it
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
  • Billman
    • 4129
    And what turbo is this??? For how much HP and how would it behave on the 2,2 or 2,45 stroker??
    It is only oil cooled! He says it has an k27.2 turbine housing
    The compressor intake has a 70mm diameter and a 52mm output diameter. The number is 5327 101 50.
    The turbine housing is number 8 and has a 59mm diameter. the numbers on it are 5327 101 6382
    He also said that it was one of the two turbos used on a Kremer Porsche 962 CK6 Gruppe C
    Go Holset or Go RS4
