Since having the aircon regassed a few months ago, I've been running the aircon all the time - to keep the system lubricated, and also to see if it leaks again (so far, so good).
However, I have since noticed that my water temps have been a bit low. I first put this down to the aircon cooling fan running all the time - when I switched aircon off, it invariably would rise to the 90 position.
Now, this doesn't seem to happen anymore, and on a decent drive, water temp basically seems to be around 70, even with the aircon off (hard to tell as the grad lines don't make sense to me!).
Eg a drive back from Cheltenham on Saturday night along the A40 then down the M40 at fairly interesting velocity, with aircon off, don't think the temp actually got up to 90 the whole way back.
Does this sound like the thermostat?
Is this a major problem?
Is it tricky to replace?
Thanks guys
Thanks guys
