turbo k26
  • s2martin
    • Jul 2005
    • 45
    turbo k26
    Hey i have just mont. this turbo, on the other standard turbo(k24) there was a hose mont. on. Where do i put that now, there is no place to put it on the new one.
  • s2martin
    • Jul 2005
    • 45
    The green spot indicate where the hose was mont. on the old turbo
    • s2martin
      • Jul 2005
      • 45
      some one must now what to do whit it
      • WabTheKing
        • May 2004
        • 2567
        does the old one not unscrew?
        • Corey
          Banned
          • Sep 2003
          • 2793
          Not if the compressor housing isn't drilled for it!!!
          Does the K26 have the oil and water line ports on it? If not you have the wrong turbo, if it does have the oil and water ports and the only thing stopping you from fitting it is your question above, then take off the compressor housing (very easy just remove the bolts holding it to the housing) and I will drill it for you if you want?
          PM to talk more.
          Corey
          01636 822288
