I need advice on making more bhp
  • audi660
    • Jan 2005
    • 162
    • Country: South Africa
    I've got an S6 with k26/27 turbo, 76mm exhaust, stiffer WG spring, RS2 injectors and boost sitting at about 1.7bar. It's roughly about 400bhp & 600nm.
    Unfortunately it's not enough
    Any ideas on how to make more horsepower without changing the turbo?
    [SIGPIC]1997 Ur-S6 SMS Revo S
  • volcano rs
    • Jun 2005
    • 2265
    you have to strengthen the bottom end if it hasn't been done already. port the head ,tubulor exhaust manifold ,larger intercooler ,bigger injectors ,different inlet manifold with a more shorter path, and even then you might have to change the turbo.
    • WabTheKing
      • May 2004
      • 2567
      600nm? have you changed your rods?
      do you have an aan manifold? if not i know where there is one :mischeif:
