I was finishing off stipping the block down last night so i can leave it in to a machine shop in the morning.
When i removed the large oil pressure switch i found it was screwed into a 17mm adapter on the block. I then removed the adapter with a 17mm socket but when i look inside the hole there is something in there, it looks like its a torx style bolt head, but on the other hand it looks like some sort of a valve. I dont want to break it so can somebody tell what the f**k that thing is and how i get it out of there?
Thanks,
Mark.
P.S. Had a quick look in etka but cant find it
Thanks,
Mark.
, best wait for one of the engine gurus like Mr Halligan to come along. I'm sure someone will know
...i'll have a bash at it when i get home and see what happens.
