we have a A4 1.9tdi (w reg)115hp that will not rev up it has come up with a fault code 18047 wiring/app sensor .Wiring has been checked /throttle pedal replaced .The car was all ok untill it had a flat battery .we can not clear code please please help i know its not a S2
if the problem occured after you had dead battery, i think that you are going to have to take it ti reapair shop that has VAG-com. They are going to have to do so called throttle adaptation. Basicly computer has to relearn how to controll throttle again, because computer lost power from battery, and VAG-com is only way to do it.
This is what is sounds like to , based on you problem description.
I hope it helps
