Stroker 20v Head Studs???
  • olsonjus
    • Dec 2003
    • 293
    I have read that the BMW 3.5L head stud kit from ARP works on stroker 20V. I am using a AAF tall deck block 236mm deck height. 95.5mm stroke. 159mm rods.
    I wanted to verify with someone that has used these first hand. I just wanted to verify that they work.
    Here are the head studs I am planning on buying:
    Regards,
    Justin
  • AnLe
    • Dec 2003
    • 291
    go to normal spare parts store and buy standard aftermarket headstud an measure it, and please report here that I dont have to do it also
    • caterpillar
      • 2480
      ARP studs
      olsonjus.@ thats correct with bmw,but i dont know what size the bmw's the studs kit are from. have the kit at home, but no marks on
      what piston are you using?? P/N and size,and comp plaese......
      • olsonjus
        • Dec 2003
        • 293
        I'm going to go with a set of JE pistons.
        29.25mm compression height
        21mm wrist pin
        -11cc dish
        82.5mm bore
        CR ~9.0:1
        Regards,
        Justin
        • Audi_CQ
          • 940
          • Country: Norway
          Regards,
          Justin
          Don't know if I was the first to discover the use for this studs, but can confirm that they work They are 12mm instead of 11mm so the holes in the head has to be bored out 1mm.
          1.4 TDI studs has also been said to fit, but haven't tried myself.
          Cheers,
          Roger
          • olsonjus
            • Dec 2003
            • 293
            Sounds good, I guess I'll go ahead and order up a set.
            Regards,
            Justin
            • Billman
              • 4129
              can someone please tell me if these head studs from BMW work and what the ARP part number is? Do they need any changes?
              i am thinking that i buy some with the low dollar price.
              Go Holset or Go RS4
              • Avanter
                • Nov 2008
                • 35
                • Country: Latvia
                • Billman
                  • 4129
                  Thanks, but witch is the original ARP number? I can find them much cheaper this way. Anyone did this?
                  Go Holset or Go RS4
                  • Kieron20V
                    • Mar 2008
                    • 1505
                    Note, this kit is not available from ARP, we build this kit using ARP raw hardware in house.
                    If you can find them cheaper yourself, why dont you do a little work and have a look??
                    You want 12mm studs the same length as the oem one, nuts and washers. If you order the BMW kit, your going to have 2 extra of everything, how does that work out cheaper?
                    Kieron.
                    1994 URS4 Avant RS2+
                      There is no ARP number, the 034 kit comes unmarked as it's put together for 034 directly.
                      Either buy the BMW studs or order from 034
                      • Billman
                        • 4129
                        Ok, lets do it easier! What is the length i want? I dont mind have 2 extras.
                        the 12mm is not enough! What is the winding dimension?
                        Please reply if you have an answer! to the questions.....i know the 034 way!
                        thanks
                        Go Holset or Go RS4
                          Here's an idea, look on the ARP website
                          • Kieron20V
                            • Mar 2008
                            • 1505
                            Jeeeez.
                            Do you not have your engine in pieces or something, so you can just measure one.
                            According to etka, the length of a standard headbolt is 173mm.
                            Hope that helps.
