NOT PAS pump but what is wrong....
  • s2avant95M
    • 1217
    • Home: England Current: United States
    OK, further to my PAS pump thread, removed PAS pump briefly and noise is still there, its coming from the left hand side from the area at the bottom in this picture? any ideas?
    cheers!!
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
  • Billman
    • 4129
    Oilpump maybe? Aircontitioning Compressor pulley??
    Go Holset or Go RS4
    • s2avant95M
      • 1217
      what is on that pulley thats under the pipe? my a/c packed up in the summer could that be a cause or symptom of the noise, i cant remember when the noise started but it was probably about that time..
      Tim
      • Jon441cc
        • Dec 2005
        • 2061
        My Friend also has an annoying rattle in the same sort of area as you describe on his Avant.
        We suspected the A/C unit.
        • mcandmar
          • Apr 2004
          • 5118
          If its not AC i would guess the idler pulley/bearing for tensioning the timing belt. My 7A had a noisy one which sounded like a high pitched squeak, wasn’t a constant noise, seemed to come and go and was worse at idle.
          Water pumps can get noisy too, especially if the timing belt is too tight. Sounds like a youdling chicken.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
            Couldbe a knackered clutch on the AC pump
            • s2avant95M
              • 1217
              is there an easy way to test to see if it is the a/c pump / clutch ? if i can eliminate possible causes it would be helpful.
              Tim
              • S2 Ant
                • 3682
                remove the A/C Belt and see whether the noise is still there after.
                Ant
                2011 Kawasaki Z1000
                • A80Avant
                  • 10873
                  • Country: Greece
                  something of similar nature.Could a worn out PAS belt be the cause of excessive power steering noise when the car is stationary?Or is this the indication of a near death PAS pump?
                  Let me note that when the car is more than 1500rpm the noise is gone.It only happens when car is stationary and on 800rpm.
                  cheers and sorry for the highjack!
                  Vasilis
                  • S2 Ant
                    • 3682
                    My PAS belt was noisy cos i thought mine was pump, but changing belt made a huge difference.
                    Ant
                    2011 Kawasaki Z1000
                    • A80Avant
                      • 10873
                      • Country: Greece
                      S2 ant...if mine cures it self with the belt change,im buying you a pint next time im in England!!!! Good news should always be rewarded!!!
                      cheers m8
                      Vasilis
                      • s2avant95M
                        • 1217
                        can i access the belt/pump from under the car?
                        Tim
                        • martinjs
                          • 3205
                          Yes, if your a/c has packed up, just cut the belt off, otherwise you'll need to remove the PAS belt first in order to get a/c belt off.
                          • S2 Ant
                            • 3682
                            As Martin said, you can access it but i think its the inner most belt of the 3, so a annoying to get in to.
                            Ant
                            2011 Kawasaki Z1000
                            • robinm
                              • Feb 2005
                              • 57
                              I have just replaced all 3 belts as they were contaminated with hydraulic oil. Now it's silent. For the PAS/brake pump it said in book that I needed a 12.5x992 belt. That was way too short. Mine actually needed a 12.5x1025 (QBB) belt.
