i was looking for a undertray and found one off ebay for £20 without the fixings.What sort of fixings do you need, as my s2 has never had a tray and in the wet the contacts on the starter get wet and we have a no go situation!also how much would a genuine tray be with fixings?
dean
dean
nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
If it's the pattern part you've seen on eBay, don't bother. I bought one and it snapped into pieces not long after being put on. The eBay auction mentioned that OEM is around £150, but I'm not sure how accurate that is.
The fixings are just a twist & lock affair, although mine's mostly held on with tiewraps.
As Karlos says, tie wraps are fine and are what most people use, work fine for me.
but if you want really ana1 you can get the original fixing kit from Marty and the guys at Vagparts here.
HTH's
Jas
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
yea i ws told to they were around £150 but the one off ebay for £20 was the last one and for some reason was thinner than the others therefore even more likely to break!have to get hold of one from vag.Had to be bump started off the garage forecourt today because of water getting into the starter!
dean
dean
but the starter is in a very prone position to getting wet especially on country road with pot holes you could disappear into,and lanes that turn into lakes as soon as it rains!Just when we got it home all the contacts on the starter were drenched to took them all off cleaned them up and then no probs!
dean
HTH's
Jas
I bought them!
(They do actually work really well, are easy to fit and 1/4 turn fasteners.... )
The Perfectionist
good to have them stops water from getting on your power steering and alternator belts .have you ever lost power steering just for a few seconds due to water on the belts?
