Hi,
I'm really confused as to what normal coolant temperature readings should be. I posted a while ago and found that my cool 'on the go' temps are common, but now I'm not so convinced that it's "normal" after some searches... so what is the definite answer of how it should behave??
Basically, one of the freezing nights I went on a run to work and it barely rose above the 50 mark... regardless of temp, once she's running warm, if I stop you can watch the guage slowly rise to 92 when the fan kicks in and brings it back down again.
What I'm concerned about, is the temp sensor - I've been reading that when it registers a low running temp then the engine runs in it's 'cold' mode and overfuels. Is this is the case? If the temp climbs to 90+, then as soon as I'm on the move it drops again - the faster i go, the lower it gets... sometimes back down below 60deg. Do i need to replace a sensor, thermostat etc, or am I just being paranoid? Should the temp stay up in the 80-90 region even on the move?
I want to ensure she's running right before I start bolting extra goodies onto the engine...
Ross
Ross
