AQN VR5 anybody ?
  • kalsket
    • Sep 2004
    • 78
    AQN VR5 anybody ?
    If you have a VW with AQN VR5 engine, I would be interested to know its VIN.
    Need it for a very special part request.
    4F 2006 avant 3.0tdi quattro
    4B 2002 S6 avant quattro
    typ85 sedan quattro with "minor" changes
  • s2avant
    • 2426
    What part are you after that needs a VIN number to order?
    Ben
    • Billman
      • 4129
      Maybe ignition parts??
      Go Holset or Go RS4
      • kalsket
        • Sep 2004
        • 78
        Billman is on the right track.
        For 1.8T engine there is wiring harness for COP:s that is really cheap and wich ETKA doesn't know. Hopefully with a VIN I could find similar harness for 5scyl.
        • Billman
          • 4129
          Check also this out! For doing a 3b work without the distibutor!
          The green letters on the menu! Problem or you maybe the language!
          Go Holset or Go RS4
          • kalsket
            • Sep 2004
            • 78
            I have read that, those aren't coil on plugs. No help for this question.
            Here is the part number for that special 4cyl harness 1J0971658L
            ETKA doesn't know it but it IS right, used it for ordering more than once.
            • s2avant
              • 2426
              The holy grail of looms. Tried finding such a loom a few times. If we knew where the 4cyl harness part number came from then maybe we could find a 5cyl version.
              I imagine the part number is some kind of repair loom for a certain country. Whether or not a 5 cylinder version exists is another matter.
              Ben
              • kalsket
                • Sep 2004
                • 78
                Ben, you are at least very close being right.
                That 4cyl loom is repair loom for USA. Hopefully there is one for 5cyl too.
                Anybody got US ETKA? is that loom number there?
                • s2avant
                  • 2426
                  I did some searching through the US TSBs (Technical Service Bulletins) and it seems they only changed the loom on 1.8T engines. All other engines just list coil pack replacement as a cure for misfires etc.
                  Ben
