What petrol? unleaded or leaded
  • ian_jemo
    • Aug 2004
    • 284
    hi all just brought an Audi S2
    I forgot to ask the previous owner what type of petrol I should use.
    The year of the car is 1991, Should it be unleaded or leaded
    Ian
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
  • lightning canuck
    • 12
    Hi Ian,
    Unleaded I assume, preferably 97 or 98RON. It should tell you on the inside of your petrol cap flap. If you've got a Tesco nearby check and see if it stocks 99RON!
    1994 S2 Coupe
    • vonbeck
      • 2455
      optimax or bp ultimate if you`ve got deep pockets
      ABY Cricket Green Pearl Coupe, blk leather
      THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
      • Alistair C
        • 693
        if memory serves me correctly, VAG have been using hardened valve seats on all their engines since the 70's ('76?). I seem to remember even MKI golfs can run on unleaded!
        • ian_jemo
          • Aug 2004
          • 284
          thanks all
          • PeteRR
            • 1326
            If it's still got the Catalysts fitted then use nothing but Unleaded fuel, otherwise they will be ruined (though a good excuse to fit cat by-pass pipes on it I suppose!).
            It should run at its optimum on Superunleaded fuel too.
