7a Cams question.
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    7a Cams question.
    What should i expect to pay for a set of 7A cams (In & Ex)? Both from low miles engine.
    Russ
    Old Stuff Reborn.
    Complete heads turn up on ebay for around £100 to £150. Not seen (m)any low mileage ones though. HTH
    • RustyNut
      • 1433
      Am i right in thinking that it's literaly just the cams themselves that are swapped over and no futher parts i.e the head also?
      I'm new to all this and i'm still trying to make sense of it all...!
      Russ
      Old Stuff Reborn.
      • pastures16
        • 2058
        exhaust cam only
        94 s2 avant
        aoc member 1116
        • Faheemo
          • Feb 2005
          • 544
          • Country: South Africa
          I bought a whole head off ebay for 90 GBP the other week.
          Dont look low milage to me but cams dont need to be low milage do they ?
          S2 Coupe fully built.
          10.9 1/4mile 0-100 in 3.5secs
          Precision 6262 turbo
          The Green Monster
          • volcano rs
            • Jun 2005
            • 2265
            i got some with 230000 miles on them with no wear ( not for sale )
              Yes, it is just the cams that are required from the head.
              AFAIK you have to transfer the cam sprocket off the S2 exhaust cam as it has the hall sensor mounted in it and is required for cam position for the ECU. The exhaust cam is of a longer duration tahn the S2 item and so allows the exhaust gasses to escape easier and improves torque throughout the rev range with minimal losses on the bottom end. The inlet cam will fit but sacrifices midrange torque for overall power and is not well suited to the S2 engine. I believe that the inlet has been tried by one of the big power boys who subsequently reverted back to the S2 (or RS2) cam he had originally as the gain in power did not outweigh the loss in mid range torque.
              HTH
                7A inlet cam does have considerably more duration than the S2 item - so yes it works better at the higher revs. Horses for courses etc etc
                • Audi_CQ
                  • 940
                  • Country: Norway
                  The "books" say so, but when measured it isn't that much of a difference. The 7A is supposed to have 224 at 1mm lift, but when measured it's 212 ! S2 is 203?
                    Phook - thats a worry !
                      Doug RS2 had his car rolling road with all the 7a inlet and exhaust, plots are on the forum.
                        It went better with 7A exhaust and standard inlet though
                          Was going to post that bit, but i can't find the thread
                          • Audi_CQ
                            • 940
                            • Country: Norway
                            Just said that the difference in duration isn't that big
                            Gain & loss is depending of rest of engine. No universal answer is possible. If you got a custom engine, you have to test for yourself
                              Thought it was Doug but didn't want to get it wrong. Was IIR 3bhp up but quite a bit less torque.
