What triggers overboost?
  • AndyP
    • 6049
    Not overboost protection, but the overboost function on the ABY engine?
    When I was driving back from the garage meet on sunday I noticed that the overboost was not working, even with my foot to the floor it was only showing 0.8bar boost, whereas with the over boost it should go to 1.1bar I believe.
    Is this triggered purely by the TPS hitting 100% or are there other variables involved?
    what gear were you in? you only get overboost in higher gears 4,5,6 (can't remember if you get it in 3)
      i think it is when the ECU senses a high load and WOT, but dont quote me on that one
      • AndyP
        • 6049
        Couldn't get it to work in any gear. I know the throttle is physically opening 100% but I don't know if the TPS is telling the ECU that.
        • S4-Sleden
          • Dec 2005
          • 220
          • Country: Norway
          I think it depends on how quick you floor it too...........
          2003 VW Passat Highline 130 TDI wagon with ALL options.
            No it's defo load related, S2entral.net test for it is to floor it up a hill in 4th gear and you should see 1.1 boost
              See here for a test: http://www.s2central.net/motronic_boost.html
              • Olle
                • May 2005
                • 30
                • Country: Russian Federation
                WG solenoid valve?
                  Originally posted by Olle
                  WG solenoid valve?
                  waste gate frequency valve, search for wgfv on the forum
                  • Olle
                    • May 2005
                    • 30
                    yep, you are correct, i meant WGFV. it also does trigger overboost, right?
                    • slow2
                      • Apr 2004
                      • 238
                      Hi Andy
                      along my way to me becoming motronic guru i have discoverd that the altitude sensor readings affects overboost function on the ABY
                      i have just removed mine in order to do resistance check will let you know what i find out
                      Dez
                      Never did overtime until i purchased........s2
                        More correctly the altitude sensor can affect all boost values because the ECUs pressure sensor works off absolute pressure... so if the alt sensor is giving a false high reading then the ECU will not allow as much boost to hit a target absolute value. Thats roughly as I understand it...
                        I also understand that rapid opening of the throttle in high gears is needed to engage the overboost mode - which lasts about 15 seconds on factory chips.
                        With VAGCOM you can check to see if the throttle positions are being correctly registered by the ECU.
                        IDLE = 0001
                        PART = 0010
                        WOT = 0100
                        Those are from memory - check s2 central tech areas for info I compiled years ago... which probably needs a tidy up but such is life !
                        • Ski
                          • 2591
                          Normally the right pedal =p
                          ABY Coupe
                            Funny that i mentioned to another forum member to check the altitude sensor the other day!
                            • slow2
                              • Apr 2004
                              • 238
                              And i did, although Paul N had already advised this as possible cause for my boost problem earlyer in the day
                              Dez
