K26 turbo
  • K7ERG
    • 1711
    K26 turbo
    I am looking for info on the K26 turbo.
    Mainly the differences between the K26 from the Audi RS2 and the Porker 944?
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • MidnightBlueS2
    • Jul 2005
    • 1653
    • Home: United States Current: Belgium
    You're maybe wondering why no one is answering...
    Try the "Search" button and type in K26 to start with... It's a question that's already been covered IIRC...
    Happy searching !
    ( They're a great bunch of Audi experts, once you get to know them , honest !!! )
    HTH,
    David
    Midnight Blue S2 - SOLD - 1993 S2 Avant
    • K7ERG
      • 1711
      RS2 - K26 all i have is K2036
      944 - K26 part no is 5326 970 6720 other numbers are 87 099 1312.
      I am looking for more info on the audi RS2 no. And if anyone can get a hold of one or point in the right direction.
      The reason i am asking is i am making a hybrid for my track car which uses the K16 manifold from the Vauxhall Calibra turbo and a S4 K24 turbo housing with K26 internal.
      I have one already on my road car and is good for 400-420PS. Just trying to keep cost down.
      Craig
      07947385043
      • K7ERG
        • 1711
        What about this K26 part no. 035147703D K26-2664G6.91 ???
        Looking for K2036 compressor.
        Craig
        07947385043
        • K7ERG
          • 1711
          Part no required Audi RS2 compressor wheels?
          Craig
          07947385043
          • K7ERG
            • 1711
            Anyone help!
            Craig
            07947385043
            • K7ERG
              • 1711
              KKK turbos
              I am looking at the differences between the KKK range and so far i have a
              K16,K24 and soon a K26.
              What i am looking at is the differences in sizes - compressor housing, exhaust compressor and inlet size.
              So far it looks like the k16 and K24 have the same size of compressor housing ( not measured yet) and the K16 has a larger exhaust side.
              I have also seen that Vmax are now using the K16 compressor housing for there K26.5/K24 turbo.
              The turbos are from the following Calibra turbo, Audi S2 and a Porsche 944.
              Any comments or info welcome.
              Craig
              __________________
              07947385043
              • Audi Parts Guru
                • 1317
                Craig
                Craig, how do you know that this comp weel is what you need?
                S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
                • Audi Parts Guru
                  • 1317
                  No such number Craig
                  • Billman
                    • 4129
                    For how much HP is the 944 Turbo good?
                    Go Holset or Go RS4
                    • Audi Parts Guru
                      • 1317
                      The early 944 turbo standard BHP figure is 220 BHP. The later 944 turbo standard BHP figure is 250 BHP.
                      The comp wheel on the later car is very slightly larger than the early car, only by a few millimetres though. Having said that it should be good for about 320 BHP with the right software.
                      The RS2 comp wheel however, is a few millimetres larger than the bigger of the two 944 turbo comp wheels.
                      And for everyones info, there are 20 different K26 comp wheel part numbers in the KKK parts catalogue
                      • K7ERG
                        • 1711
                        I have been told this is the compressor wheel i need to run from the company that made my first turbo. It is a K24 housing using the K26 internals from the RS2. I bought the 944 turbo just for the housing to compare sizes.
                        Craig
                        07947385043
                          Standard S2 turbo is KKK5324-970-7000
                          Audi part number is 034 145 702
                          RS2 turbo is KKK5324-970-7200 (also seen 5324-988-7200 listed)
                          Audi Part number is 034 145 703D (earlier RS2 listed 034 145 702B)
                          Cold side is 5326-101-5160
                          Compressor wheel is 2672GGC
                          Hot side is 5326-101-7388
                          Other info I found -
                          BEARING HOUSING K26 D75/51/41,
                          TURBINE HOUSING K24-6.12,
                          SHAFT&TURBINE WHEEL K24/G,
                          For a compressor map visit the link below -
                          RS2 turbo is good for 360-380bhp when properly timed and fuelled on the S2. Thats about 37lbs air per minute in rough numbers.
                          • Audi Parts Guru
                            • 1317
                            Paul,
                            I'm not sure where you got the above part numbers from but they are not what is listed in the 3K parts catalogue for the RS2 Turbo. The rest of the info seems ok though.
                            Can I ask where you got the info from?
                            Paul
                            • Krists
                              • 73
                              • Country: Latvia
                              I don't really know, that You're on the right way, Craig. In fact, if You can build K24/26 hybrid - it won't be capable of 420ps - and it won't be on the +350hp line like rs2 can ... original rs2 uses K27 compressor wheel with 2.6" bottom dia. 1.9" upper dia - the hotside wheel is a bit smaller than original K26 wheel.
                              944 has all K26 turbo , later 89' 944 and 944S has bigger hotside housing - aka K26#8.
                              I've built K26/27/29 turbo with K26#6 hotside - only this can kill the rs2 in high rpm with 400+ hp. If You want to make a better turbo from KKK parts then this is way to go! Not K24/26 ... 100% it won't be more than 315hp on 2.2 5cyl 20VT. Well not sure if You place better cams in. But this is an another story for all turbos mentioned
