I'm getting pretty serious about doing a 4cyl turbo project in my coupe (fireproof suit on
) i'm going for 4 cyl for various financial reasons and the fact it'll be easier to get rid of a 4cyl turbo engine in the future in this area. however, i'd like to stick with as many OEM parts as possible. to that end what would be your recomemndations for an IC? f
or the start i'll stick with 250 odd hp but we all know boost is addictive :mischeif: if i see things the way i think i do, the S2 IC is off to the side whereas the RS2 is up front on the fancy crossmember. given my modest output, which would be the better to go for?
thanks for the help (i'm very much a turbo noob!)
) i'm going for 4 cyl for various financial reasons and the fact it'll be easier to get rid of a 4cyl turbo engine in the future in this area. however, i'd like to stick with as many OEM parts as possible. to that end what would be your recomemndations for an IC? for the start i'll stick with 250 odd hp but we all know boost is addictive :mischeif: if i see things the way i think i do, the S2 IC is off to the side whereas the RS2 is up front on the fancy crossmember. given my modest output, which would be the better to go for?
