fuel pump
  • Jon441cc
    • Dec 2005
    • 2061
    fuel pump
    Looks like more money to spend.
    i changed the dreaded fuel filter on my avant recently and ever since the car seems to stutter occasionally and sometimes the engine dies when stationary. I have also noticed that when i floor the accelerator i can hear gurgling from the fuel pump. ive checked for leaks on the banjo fittings and all seems well, just wondering whether the new filter has put more strain on an already knackered fuel pump.
    This car is bleeding me dry
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Is your breather ok?
    SS
    • Jon441cc
      • Dec 2005
      • 2061
      Good question, not to sure on where that is located on the avant
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Funk knows. I know how to rip it out of a 3B Coupé.
        SS
          definetly check your breather, there was a conversation about this at the garage meet. If anything a new fuel filter should free things up since there isnt as much crap stuck in it.
          Unless you have got a bit of an air lock somewhere??
          • Billman
            • 4129
            What is the breather??? Where is it on the RS2?
            Go Holset or Go RS4
            • AndersS2
              • Sep 2005
              • 1364
              • Home: Norway
              Have you sorted this one out yet?
              Because i have the same symptoms, but my dont want to start at all now.
              How do i do the Fuel filter change?
              pics?
              and what is the breather? (turbo? LOL)
              Anders - S2 Avant Clubsport - 8pots or die!
              • Jon441cc
                • Dec 2005
                • 2061
                Found out it was the coilpack wiring in the end and the gurgling was due to an airlock.
                Put a search in on fuel pump, theres plenty of info on it.
                Have you checked for any blown fuses?
                • AndersS2
                  • Sep 2005
                  • 1364
                  • Home: Norway
                  Yeah, i'm reading AndyP's fuel filter thread now (here).
                  All fuses in the box under the hood seems allright though.
                  But did you change all the coil's too? or just the coil wiring?
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    The breather is the tube that vents the air/fuel vapours out of the fuel tank. Normally, for emissions control it is routed to the inlet manifold, through the N80 valve and the carbon canister.
                    I had trouble with the fuel tank pressurising, so I removed my carbon canister and all the associated pipework. The fuel tank now vents through a tube and out the rear of the car.
                    The N80 is still plugged in, but is not plumbed in.
                    HTH
                    SS
                    • Jon441cc
                      • Dec 2005
                      • 2061
                      I changed to 1.8t coilpacks, have you checked fuse #32?
                      • AndersS2
                        • Sep 2005
                        • 1364
                        • Home: Norway
                        Ok, will triple check that tomorrow.
                        What does that control btw?
                        And its the same fuelfilter for the rs2 as for the s2 avant right?
                        • Jon441cc
                          • Dec 2005
                          • 2061
                          #32 = Timing III and fuel pump
                          (Filter)
                          Not sure if there the same part... i would of thought so
                          • alg
                            • Apr 2004
                            • 1160
                            HTH
                            So I had better not light up a fag when standing behind your car Is that safe ????
                            Alastair
                            RS2
                            • AndersS2
                              • Sep 2005
                              • 1364
                              • Home: Norway
                              (Filter)
                              Ok, checked it, the fuse seem alright, but how about the red-wires in my fusebox?
                              Are they for the alarm i got? I know there use to be a loud stereo in there, but i tossed it out.
                              Pic of fusebox:
                              I have to undo the coilpack too, and see if there is any spark in the plugs. but kinda tricky when i'm alone
