Aux rad fans
  • s2_southwest
    • Oct 2004
    • 823
    Aux rad fans
    Has this subject been discissed before? i didn't find anything on the forum. But i thought about the possibility of adding maybe one or two small electric fans? Would be easy to add a stat into the coolant pipes to control it electronically.
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
    Problem is, one by one forum members are ditching the aux rad.
    I would have thought you'd want to control the aux fan off the main rad fan? be easier i'd imagine.
    • s2_southwest
      • Oct 2004
      • 823
      there is that yes. but i was worried about using the same circuit drawing too much current. i found some thin 6" diameter electric fans that draw about 5 or 6 amps max.
      you can set them up to maybe come on before the main one does.
      Just an idea i had. be interested to see any pics of this done...if not i may take the plunge myself lol
      • S2 Ant
        • 3682
        my only question is why???
        Ant
        2011 Kawasaki Z1000
        • s2_southwest
          • Oct 2004
          • 823
          to bring the operating temp down a little, we all know they run hot.
          thought it might help with high output engines
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            They do?
            SS
            • s2_southwest
              • Oct 2004
              • 823
              if they didnt, why would they have two rads?
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Mine doesn't. Tom's doesn't either, and that might tell you something.
                SS
                • s2_southwest
                  • Oct 2004
                  • 823
                  i was tempted to get rid a while back when it started leaking, but ive left it in. i may well get shot of it if you guys dont think it would bring the temps up too much. Would certainly make space for a larger oil cooler
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    When I got my S2, there were no fins left in the aux rad. So I decided it wasn't doing much cooling, and removed it.
                    SS
                      From what I have read on the forum, the UK barely gets hot enough to need the extra capacity that the aux rad provides. Abroad this is probably a different story
                      • S2 Ant
                        • 3682
                        Mine went ages ago, mines never run too hot... ever.
                        Ant
                        2011 Kawasaki Z1000
                          Ditto
                          • s2avant
                            • 2426
                            Originally posted by Jamo
                            Ditto
                            Ditto, too.
                            They run cooler without as you get more airflow over the engine.
                            Ben
                            • HPmuirt
                              S2Forum April Fool
                              • Apr 2005
                              • 3014
                              Why not just set the main fan to come on at a lower temp then?
                              Cheers n
                              Si
                              Subtle mods here and there
                              2011 A5 3.0 TDi - Lava Grey
