Intake air temp sender fault?? Do i just replace?
  • s2dude
    • Nov 2005
    • 1631
    OK. So me and a mate hooked up Vagcom to my 3b the other day as part of a troubleshooting session...
    There were the fault codes that showed up..
    Does anyone know much about Intake Air temp sensor(s)....
    Do I just need to replace it or is there somehting else that could be causing this fault?? (a short by the look of it)
    I'm told the engine speed sensor will always show as the engine is not running??? is that correct?
    TIA
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    G28 is indeed normal when the engine running.
    I had an intermittent fault with my G42. It turned out to be a loose connection on the sensor itself.
    SS
    • s2dude
      • Nov 2005
      • 1631
      Thanks for that mate.
      I will take it off on the weekend and see if I can find anything amiss..
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        No need to remove it. Just carefully put back the boot on the connector, check the two connections, and test it.
        Originally posted by s2central.net
        A DMM can be used to measure the resistance of this two-pin device with the connector harness removed. With the engine OFF long enough to cool sufficiently, at an ambient air temperature of 20 degrees, a value of 450-650 ohms should be measured across G42.
        Maintaining an ambient temperature of 20°C may be a problem here this time of year, but you should get the idea.
        SS
        • s2dude
          • Nov 2005
          • 1631
          No need to remove it. Just carefully put back the boot on the connector, check the two connections, and test it.Maintaining an ambient temperature of 20°C may be a problem here this time of year, but you should get the idea.
          Great.
          Thanks. I will try that tomorrow. Like you say I should get near that reading even if ambient is out!
