Hello everyone!
First of all, sorry for my bad english, havent write in english for a long time..
Some weeks ago I brought Audi S2 2.2 turbo (3B engine code), very good car in very good condition! You can view some photos here if you want to -> http://foto.inbox.lv/maxz/S2
So, once I have this car I want to make a little engine upgrade. First of all, I want to decrease the turbo holle (I dont know is this right in english). I have readed that one of ways how to do this is to add a blow-off valve or upgrade the stock by-pass. Both of these valves seems ok for me, but some people told me that blow-off is not good for some turbo engines (how its with audi S2?). I mean.. blow-off can damadge lambda and other stuff because of the rich fuel. Is it true? Today my friend from car-store told me that lambda is right for that - if the fuel goes too rich, lambda sends some information to ECU un and so the fuel doesnt get so rich.. maybe sounds too lame, but I realy dont understand this all
but if its right, then there should be no problem with blow-off!
In the end. What you guys sugest me to do? What valve should I install on my S2 - blow-off or replace the original by-pass with a better one? If the blow-off will not do some bad things to my engine, then maybe I should chose better it? And how about those blow-off's that goes PSSHHH and some of oxygen puts back in to the intake colector (dunno if I wrote right)?
uff.. it was hard for me to write this stuff, sorry for this long message. I hope that someone will understand my wishes and problems!
but if its right, then there should be no problem with blow-off!In the end. What you guys sugest me to do? What valve should I install on my S2 - blow-off or replace the original by-pass with a better one? If the blow-off will not do some bad things to my engine, then maybe I should chose better it? And how about those blow-off's that goes PSSHHH and some of oxygen puts back in to the intake colector (dunno if I wrote right)?
