Rod bearings
  • RSCoupe
    • Dec 2003
    • 120
    Rod bearings
    For high HP motors (400-500hp), is it a good idea to use the "violet" rod bearings for both the upper and the lower bearings? Or is this not necessary.
    Stock:
    "Violet" - upper bearing
    "Yellow" - lower bearing
    Mark Siggelkow
    '90 CQ 20vT - NASA GTS-5 (R.I.P.)
    '90 CQ-R - NASA GTS-4/5
    '00 A4 1.8TQMS (Wife's Daily Driver)
    '12 TT-RS (Wife's new DD, on order for May European delivery)
    '62 Porsche 356B (another race car)
    '03 Kawasaki Z1000 (toy)
  • Mihnea
    • 1288
    Mark,
    As I said on the Kruemmer list, yes, it is highly recommended to do so!
    HTH,
    Mihnea
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • Sweeper
      • 1317
      • Country: Latvia
      What s Violet yellow and other bearings ?
      Vadim.
      • Mihnea
        • 1288
        Vadim, the upper bearing (violet) on the ABY/AAN/ADU motors is reinforced, whereas the lower one (yellow) is just a plain bearing just as both of them are on a 3B. Hence my recommendation to get RS2 bearings (or 2 sets of upper ones) on RS2-spec 3Bs.
        HTH,
        Mihnea
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • Glen Chamberlain
          • 375
          So what is fitted to the ABY's? Reinforced upper and normal lower big end bearings? What sort of tourqe figures require to run on both reinforced bearings?
          Money is everything! Second to Power of course!!! But money breeds power??
