Vag-Com Diagnostic analysis. Help Please
  • Bowlerwell
    • 1052
    ok, I've just run Vag-com.
    I had 2 faults, but can't remember one of them... I think it was a 561...
    Anyway, i'll post more about that when it appears again.
    I have a 513 fault:
    00513 - Engine Speed Sensor (G28)
    03-00 - No Signal
    What can I do to investigate/sort this problem?
    Fyi, I am an electronics graduate, so I am familiar with a multimeter etc... I just don't know where to connect it.
    What is G28?
    What is J220?
    Is there a list of that these numbers mean?
    Thanks folks
    JB
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
  • Billman
    • 4129
    Was the engine running when you run the test??? I think G28 comes when you pull the Fault codes when the engine is switched off!
    Go Holset or Go RS4
    • dm80
      • Apr 2005
      • 812
      Yep.. he's right. If you clear it, then run VAGCOM again with the engine running... miraculously this will have disappeared. Loads of folk will tell you this.. just bein a smart erse
      • Bowlerwell
        • 1052
        lol... ok... oops.
        Thanks folks
        John Bowlerwell
        Electronic Engineer
        Present:
        Previous:
        • Bowlerwell
          • 1052
          So, maybe i'm a bit of a dunce...
          I tested a lot of the control modules, and it hardly found any of them. Would having my engine on have made any difference? Which modules should I find? I got engine 1, airbag, and only a couple of others...
          John Bowlerwell
          Electronic Engineer
          Present:
          Previous:
            What engine you got ?
            If its a 3B then that's all you'll be able to see with VAGCOM...
            If its ABY then you'll get extended engine diagnostics (including datalogging), the newer ABS and airbag where fitted. That is all.
            If you had a LHD car with aircon you'd also get that, but we RHD territories got shafted with the analog aircon system.
            Paul
            • Bowlerwell
              • 1052
              Thanks Paul.
              How do I access these extra engine diagnostics?
              Do I need my engine running?
              Thanks.
              JB
              John Bowlerwell
              Electronic Engineer
              Present:
              Previous:
                On the ABY they won't look like extras, unless you've logged onto a 3B.
                The 3B only reports ten fields of data in Group 0.
                The ABY (AAN and ADU) have lots of other more useful Groups of data that you can log to disk with the full version of VAGCOM. Its great for diagnostics and performance checks / comparisons.
                before you ask - no you can't log boost. Its a very annoying omission on the ECU diagnostics.
                Paul
                • Bowlerwell
                  • 1052
                  How do I access this Data-logging?
                  And what is the "Single Reading" section for?
                  And is there a list somewhere of what these channels represent?
                  Thanks!
                  John Bowlerwell
                  Electronic Engineer
                  Present:
                  Previous:
                  • iain1067
                    • 984
                    vw vortex site under the technical section has a lot of info on vag com it's sponsored by ross tech
                    Iain
