what is an RS4 engine worth?
  • DamoM
    • Feb 2005
    • 352
    Thinking of a conversion into a UR quattro and was wondering how much an engine like this was worth. Realise that it is the wrong site to ask but there are people on here that really know their stuff.
    Also, how difficult is it to build an S4 engine to RS4 spec?
    I know, I know...what am I thinking of...?
    *1986 ur quattro,2.5 stroker
    *1995 Nogaro Blue RS2,Md357
    *1991 RR 20v quattro
    *2000 Nogaro Blue RS4,RS6 turbos,tubulars,custom 3" downpipes,Miltek,FMIC,big injectors,RS6 big brakes,RNS-E satnav/TV,592bhp/600lbs
  • Mihnea
    • 1288
    give us a call tomorrow
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • Jon441cc
      • Dec 2005
      • 2061
      http://cgi.ebay.co.uk/Audi-RS4-Engin...QQcmdZViewItem
      • DamoM
        • Feb 2005
        • 352
        Thanks Jon...that's the reason I was asking!!! Is about £2000 over the going rate from what I can ascertain!
        • Donutking
          • Sep 2006
          • 27
          so how are you doing on this quest i am in the same boat as you.
          • spink
            • 4382
            Seen a few for sale over the last few months,all seem to be 4 grand+ with loom and ecu.Dont seem any cheaper in Germany.
            • DamoM
              • Feb 2005
              • 352
              Do you mean with regards to the engine conversion? If so then basically i have stripped all of the running gear off of a 20v quattro and have all of the subframes, gearbox, engine, turbos, intercooler (front mounted) etc etc to go on. Am having some custom exhaust manifolds and a custom system made up by Miltek through QST and am scratching my head with regards to what to do with engine mounts.
              What are you up to?
              • Corey
                Banned
                • Sep 2003
                • 2793
                Then you're not asking in the right places
                Corey
                01636 822288
                • spink
                  • 4382
                  how about an rs6 engine instead
                  http://cgi.ebay.co.uk/ws/eBayISAPI.d...DME:L:RTQ:UK:1
                  • markrs2
                    • 185
                    You have a bolt on solution that allows you to fit and an rs4 engine into a type 89 chassis then Corey?
                    • DamoM
                      • Feb 2005
                      • 352
                      Sorry, I answered with a quote from the wrong post!
                      What are you up to?
                      • Henka
                        • 585
                        • Home: Sweden
                        I'd have a little look over at motorgeek.com. At least one guy there mounted a 2.7TT into a CQ (T89/B4 are the same!). There is also talk about a RS6 conversion but that's only gotten as far as buying an engine.
                        • markrs2
                          • 185
                          I pretty sure the front chassis members on the V6 B4's are different to the rest of the range to allow a different engine mount to be used.
                          • Donutking
                            • Sep 2006
                            • 27
                            im hoping minhea can shed some light as well on this subject
                            or anyone that is in process. does it seem doable within 10k USD?
                            • Mihnea
                              • 1288
                              I can't see anyone doing much with 10k USD honestly... unless you can fabricate your own parts so you don't have to pay someone else to do it...
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
