Hello everyone,
after i found out what the chip my RS2 has,gives to the engine,i was wondering if anyone knew what changes does it do pressurewise.
Since a new turbo is going to be installed and the samcos as well,hoping that i dont have any intercooler or exhaust manifold losses(intercooler mod also done),i was wondering what boost pressure should i be able to witness on my gauge now?
I know that top boost on stock ECU is 1.4bar.Previously i barely noticed 22psi at the beggining,but later on it dropped to 18psi and only in 5th and 6th gear would it reach 20psi.
Now i will also install Flexx's boost gauge(thanks flexx) which i picked up from the bay so i will have the measurements in bar.
So does the MTM chip bring the boost up to 1.5bar? or 1.6bar?or more?How does it work giving 330hp and 485Nm?
cheers
Vasilis
cheers
Vasilis
