Try to find...
  • alexdu14
    • Aug 2005
    • 24
    Try to find...
    Hi, can you guess which engine is it?
    3B - AAN - ADU - ABY
  • alexdu14
    • Aug 2005
    • 24
    So
    • DJones
      • Jun 2005
      • 2020
      Aby?
      • Jon441cc
        • Dec 2005
        • 2061
        AAN bottom end + 3b cylinder head
        • ThatGUY
          • Sep 2004
          • 794
          the AAN has the AC unit on the other side of the block.
          //-\\ ((_)) //)) //
          • ThatGUY
            • Sep 2004
            • 794
            Unless that is modded to place the AC compressor on the turbo side.
            The head lookes like it has coil pack which would mean its not 3B valve cover right?
            //-\\ ((_)) //)) //
            • Corey
              Banned
              • Sep 2003
              • 2793
              Originally posted by DJones
              Aby?
              And the winner is...
              ABY
              Corey
              01636 822288
                have to agree, its an ABY. You can tell from coil cover on the top, where the AC pump is mounted and they way the tensioner is fitted for the cambelt.
                • porkkis
                  • 1994
                  But 3B camwheel...
                  New style block with old style head. Old style oil pump with cambelt wheel but still the new style tensioner and water pump.
                  Hard to tell if the head is new style or old style as the camwheel is on the way. I mean the hall bracket here.
                  • alexdu14
                    • Aug 2005
                    • 24
                    Well, i have to admit that is not simple, it's an aan block engine with aby accessories.
                    Some of you says there maybe 3b parts - anyway the seller didn't tell me that...
                    How can i be sure?
                    • Billman
                      • 4129
                      The RS2 ADU has the AC also at this place!
                      Go Holset or Go RS4
                      • porkkis
                        • 1994
                        That's a 3B cam wheel and oil pump with roller for sure.
                        These engines have only 1 roller for the cam belt and you have 2...
                        Do you have a stub ignition distributor on the head like on early AAN engines had? That could explain the cam wheel.
                        • porkkis
                          • 1994
                          Ah I see the hall sender hanging on its wire there. You need a ABY/AAN cam wheel for it to work.
                          Remove the roller from the oil pump and use AAN ABY cam belt and you should be fine.
                          • alexdu14
                            • Aug 2005
                            • 24
                            Thanks!!
                            Now i understand, this engine is an early aan, this is why was fitted a stub ignitor, it
                            explains too the old style elements...
                            How can i stop the hole for ignitor? it needs to be proof
                            I hope i would find belts...
                            • porkkis
                              • 1994
                              First check that there is place for the hall sender behind the cam wheel. There might not be so you may need to use the stub.
                              Belt is not a problem if you remove the lower roller from the oil pump.
