GT2871 or 3071 ?? Upsides and downsides
  • S4-Sleden
    • Dec 2005
    • 220
    • Country: Norway
    I have now sold my KKK K26/27 (KX450) turbo so now im going to buy a Garret GT turbo. But im not sure to choose the 2871 or the 3071.........i can live with boost at 3K rpms. But i have read some stuff about compressor surge with these turbos. Im going to use 7A exhaust cam and AAN intake cam.
    2003 VW Passat Highline 130 TDI wagon with ALL options.
  • S4-Sleden
    • Dec 2005
    • 220
    • Country: Norway
    And another thing: Can i still use my software which was intended for my K26/27 turbo ?? I dont see any reasons why i cant use it but im asking anyway........
    • jade
      • Jan 2005
      • 1811
      • Home: New Zealand Current: Spain
      Hi i will changing this week for a 3071r on my rs2, chipped , K&N , exhaust Supersprint
      down pipe rs4 back i will be running on rs2 map to start
      let you know what happens on friday
      Jade
      RS 2 580HP
      • Faheemo
        • Feb 2005
        • 544
        • Country: South Africa
        Take the 3071, just got my car done with a GT3071 and damn she is sweet.
        Spools up nice and early from 2500 rpm and holds good boost all the way to redline.
        good head room also on the top for efficency.
        be sure its the 63AR if u dont want the lag.
        read this post if u havent already:
        Recently I've received some questions concerning the suitability of the GT-2871R and 3071R for street use, specifically with the loss of drivability. Since I own a chipped 200q20v still wearing its stock K24 and I do tuning on a pair of 200's that have at various times had an RS2, an RS2 Comp...
        S2 Coupe fully built.
        10.9 1/4mile 0-100 in 3.5secs
        Precision 6262 turbo
        The Green Monster
        • S4-Sleden
          • Dec 2005
          • 220
          • Country: Norway
          http://www.motorgeek.com/phpBB2/view...c8ddfb56aa8672
          Thanx alot for that link!! I talked to a friend that works in a tuning company here in Norway and he told me to go for the 3071 instead of the 2871. The 2871 is a bit too small in his opinion,but its not a bad turbo!!! So i ill go for the 3071. Interesting reading on the Motorgeek forum
            2871 too small? it does 450 bhp!!!
            • S4-Sleden
              • Dec 2005
              • 220
              • Country: Norway
              Im afraid about surging ive read about in another thread. Doesnt seem like thats a problem with the 3071.........talked to a friend that works with a Norwegian tuner and he recommended 3071 instead of the 2871.
              • Audi_CQ
                • 940
                • Country: Norway
                Way too small, and same about 3071
                • diesel des
                  • 3896
                  Any hard info on the full gt30R with the 76mm wheel? thats the one i have but the cars is still being painted?
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    Hvis du har en 2.5 motor , ja.
                    SS
                    • Alistair E
                      • 479
                      Can someone give a brief explanation on internal vs external wastgates. Been looking at a Gt2871R but it has an internal wastegate. I believe an external wastegate is better. Is it possible to convert/modify.
                      Also, is there a difference between the turbo fittings on the s2 and rs2 exhaust manifolds? What are the correct turbo housings to fit (T25, T04 other)?
                      Anybody any opinions and potential upsides/downsides of the following spec turbo
                      GT2871R
                      Specs: 52 trim 71mm GT compressor, full ball bearing center, 53.8mm 76 trim tubine wheel in a .64 A/R T25 .
                      Alistair
                        GT2871R
                        Alistair
                        You need to look at the GT2871R with the K26 hotside which will bolt onto a standard manifold and retain the external wastegate
                        • jade
                          • Jan 2005
                          • 1811
                          Hi All
                          While fitted a gt 3071 to my friends rs2 this week 2 problem the housing of the turbo is hitting on body will try new engine mounts & see if that helps also do not think rs2 air box will fit now as the turbo is that much bigger .i Took it for a short drive no surging problems Need fit boost gauge to see what going on there seems to run well
                          Will fix small problems & do more road tests next week
                          Jade
                          RS 2 580HP
                          • kalsket
                            • Sep 2004
                            • 78
                            I'm running GT2971R with internal wastegate and see only one reason for using external WG, use of original ex mani. If you change for tubular ex mani, use internal WG.
                            4F 2006 avant 3.0tdi quattro
                            4B 2002 S6 avant quattro
                            typ85 sedan quattro with "minor" changes
                              It's not as effecient as using an external wastegate as internal has lower flow than external when open.
                              Pays your money take your choice.
