High boost
  • jade
    • Jan 2005
    • 1811
    High boost
    Hi all
    Just had a good run up the motorway in 6th put my foot down 2.2 bar should be 1.8 bar what would cause this ???
    Cheers Jade
    RS 2 580HP
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    could just be right air temp and enough oxygen for the engine.
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
      is that absolute or relative pressure?
      Probably because engine is at higher load and builds boost more quickly before the WG responds and opens. Also may be the overboost kicking in
      • jade
        • Jan 2005
        • 1811
        21 c to 25 c today
        Thats what it says on boost gauge 2.2 in overboost
        RS 2 580HP
          is your car an s2 of S4? if it is an S4 with the boost display on the dash. If this is the case. The dash display is absolute and not relative so it would be getting the overboost of 1.1 bar.
          • jade
            • Jan 2005
            • 1811
            ´¨Its a chipped rs2 with chip from ts tuning & rev tech boost gauge 1.4 with rs2 chipset 1.8 with ts
            Cheers Jade
            RS 2 580HP
