!.8T coils in 3B head :(
  • audiman
    • 4827
    It would appear that 1.8T coils dont fit the r/cover of the 3B as the stem part needs to be longer. Anyone got over this problem before?? I guess I could use an ABY r/cover??
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    hmm
    dont think these mix, just make sure that they plug good so no moisture gets down in there..
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
    • Jeffer
      • 2057
      IIRC someone made the hole larger for the top part of the stem to snug-fit the r/cover. Not sure if this was for the 3B head btw.
      RS2 Black - stock 315 HP
      RS2 RS blau - stock 315 HP
      Sport Quattro - 1005 HP
      High Octane website
      • zlobo
        • 967
        i got them in mine... and you can fit them under the cower if you peal some plastic of the coils... i post pictures to night
        ABT C5 Lord Of The Rings
        2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
        2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
        2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
        kostic.nu
        • zlobo
          • 967
          here is one and i post an other one on the coil later...
          kostic.nu
          • repo
            • Dec 2004
            • 893
            I took off the rubber seal from the coils, and grinded the plastic underneath the seal, so the coil fitted into the hole of the 3b cover.
            Also I grinded the collar a little lower from the cover.
            Works fine. Took an hour to fit them.
              However you modify the 1.8t "115L" coil packs to fit on/in the 3B head/camcover, make sure that the end of the coil pack goes down deep enough to "snap" on to the hex part of the F5DPOR spark plug.
              Dave F.
              • zlobo
                • 967
                here it is how mine looks
                kostic.nu
                • audiman
                  • 4827
                  Excellent pics and info men!! Is this the same coil part number that a lot of people are now fitting to there cars elsewhere on the forum?? If not can you add the part number please
                  Audi UR Quattro
