Vf 34 Ihi Turbo
  • Albie S2
    • Oct 2004
    • 138
    • Country: South Africa
    Vf 34 Ihi Turbo
    Hi
    how would a ihi vf34 ball bearing turbo work on a 5 cyl 3b??????????
    thks chris
    www.cardomin.com/member/745893
  • maRS2
    • Oct 2003
    • 366
    • Home: France Current: Thailand
    It's the one from the Subaru STI right?
    I think you could get around 350- 370 hp as I know lot of guy running 360 on the 2000cc subaru engine with this OEM turbo
    RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
    • Albie S2
      • Oct 2004
      • 138
      Ihi
      Yes it is from the sti subaru i am running stand alone ecu with custom headers an a k26 hotside wich is cut to take the k27 wheel with a K28 compressor side car is pulling strong from about 3800rpm up to the redline 7800rpm but low end torque is a problem with this turbo also 76mm downpipe had the car on the 1/4 mile wich gave me 13.02 with clutch slipping from 3rd need to know if the IHI will do better?.
      Thks Chris
